OT: Portning af topstykke.......
Creed
Tilmeldt: 30. dec 2006, 13:51
25. dec 2007, 17:51
Læs lige hvordan en gut i udlandet har portet sit topstykke...
Hey guys, I've got a 98 1.8T. I've had a k04 and chip for a while and wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises.
Help! Can anyone tell me what to do! My buddy only does Hondas so he doesn't know much about Audis.
http://www.audiforums.com/m_693578/mpage_1/key_/tm.htm
:shock: :shock: :shock:
Hvis fjolset vitterlig har gjort dette fortjener han ikke en bil...
Men det er da god læsning sådan en dagen der på juledag... :D
PS: Hvis der er nogen her i klubben der har prøvet samme metode hører jeg gerne fra jer!
Krede ~ (Kristian)
ulrichhansen
Tilmeldt: 31. jan 2006, 21:37
25. dec 2007, 18:01
F**k en klovn.. sjovt at læse alle de kommentare han har fået.. :lol:
Saab 9k CC 2,3T '91
Medlem nr. 159
Sharky-1
Tilmeldt: 10. okt 2007, 20:22
25. dec 2007, 18:21
Det bekræfter hvad jeg mistænkte om AUDI ejere...
To bee a SAAB, or NOT to bee a SAAB.
25. dec 2007, 18:58
Så er det jo jeg kommer til at tænke på ham med bmwén der fik en klud omkring knast akselen. hans historie gik nettet rundt
http://forum.e46fanatics.com/showthread.php?t=311931
SGT
Tilmeldt: 3. jun 2004, 19:53
25. dec 2007, 19:05
Portning på den nemme måde, og så alligevel ikke :lol:
SAAB är bra!
25. dec 2007, 19:10
hmm jeg kommer til at tænke på at min autolaker kan sandblæse med 10 bar. hvis nu man sætter den direkte på LMM imens motoren kører så kan man både få renset LMM. rør. ic. indsugning. ventiler turbo og udstødning på ingen tid samtidig med en portning. jeg er helt sikker på at jeg kan lokke ham til at lave et godt tilbud hvis vi er nogen stykker så skriv jer på listen hvis i er interesserede. jeg starter selv
1) Casper :mrgreen:
Creed
25. dec 2007, 19:11
2) Krede
Kommer med 3 biler! og en citroen! :mrgreen:
Krede ~ (Kristian)
ulrichhansen
25. dec 2007, 19:15
3) Andreas
Min scooter kunne godt bruge en ordenlig omgang portning og polering af cylinderen! :mrgreen:
Saab 9k CC 2,3T '91
Medlem nr. 159
T-Slot
Tilmeldt: 20. maj 2004, 00:46
25. dec 2007, 20:32
Nogen der vil forklare til os ikke tekniske hvad en portning af toppen er???
Mvh Slot -Medl. nr. 242.
Saab 900S 1991
Saab 9000CDEt 2,3 200Hk, 1995
Saab 9000CST 2,3 200Hk, 1995
25. dec 2007, 20:42
Det er når man udvider indsugnings eller udstødnings kanalerne så de bliver større end de er standart hvilket giver mulighed for bedre/større flow. og nej det gøres IKKE ved at hælde adskillige kilo sand igennem motoren
T-Slot
25. dec 2007, 20:45
:lol: Nej det er nok ikke så heldigt. Tak for svaret.
Saab 900S 1991
